fault caravan 96 ignition
12 years 1 month before #41814 by manual-mecanica
fault caravan 96 ignition published by manual-mecanica
Greetings I have a fault with a Grand Caravan 96 when opening the switch all the icons of the board mark but when you turn on it does nothing.
12 years 1 month before #41823 by manual-mecanica
Manual-mecanica response on the subject fault caravan 96 ignition
You have not giving anything but what do you mean when you do not give anything off the bullfights of the board does not turn the starter engine, in pesa for checking the battery terminals that are lymp and checks that the battery is loaded and in which condition it is located
12 years 1 month before #41829 by manual-mecanica
If it is not the guilt of the Czech battery that the contact sheet exits the starter engine if it does nothing and even the exitation signal comes out the start that is the problem
12 years 1 month before #41834 by manual-mecanica
Hello, I had a similar problem but with a Hyundai Santafe but it turned out that it was the valero of the compressor of the air conditioning attached that Asia would not rotate.
12 years 1 month before #41849 by manual-mecanica
Thank you Checare
