Megane Cueta start in cold
12 years 3 weeks before #41917 by manual-mecanica
Megane Cueta start in cold published by Manual-Mecanica
Hello friends of the forum, I tell you I have a small incombing in my megane 98 1.6 8V, I cost me a lot to start it, then when it is hot it starts to the touch, it changes spark plugs, but it is still the same.
Someone can give me a hand where to already glimpse thank you very much for your attention.
12 years 3 weeks before #41921 by manual-mecanica
Manual-mecanica response on the megane topic is to start in cold
Good compa, you must start with the ECT, IAC sensors, and the IAT that are directly related to the control of the minimum and start in cold, if you can take it to a scanner to get the doubts.
12 years 3 weeks before #41926 by manual-mecanica
Usually in Renault when it costs the start is either the refrigerant temperature sensor or the upper dead point sensor, the latter is called, magnet captor, position of position of the followñal and as 20 names more hahahaha
12 years 3 weeks before #41955 by manual-mecanica
Well friends I will try these sensors greetings I will have aware of what is happening.
12 years 3 weeks before #41956 by manual-mecanica
What other things do you observe, something like black or decompressed smoke or any other track?
