Corsa problems
12 years 3 weeks before #42011 by manual-mecanica
Corsa problems posted by Manual-Mecanica
Hello I have a problem with a Chevrolet Corsa I break the fuel pump and change it since the spark plugs is changing it is like they are not burning always drowned the cables and spark plugs but it remains the same.
what can it be?
12 years 3 weeks before #42012 by manual-mecanica
Manual-Mecanica Response on the subject Problems with Corsa
Hello,
if the symptom is like this fuel ex -ease after changing the pump is likely that the pressure regulator does not work for you that in the Corsa
12 years 2 weeks before #42034 by manual-mecanica
you wanted to put a pump of less or greater pound and not the one that corresponds
12 years 2 weeks before #42036 by manual-mecanica
Verify the current pump pressure and compare it with the pressure of the original pump, to revise the repair manual with a pressure should work for the pump according to the manufacturer's specifications.
You just have to compare the pressures, there must be an error ..
12 years 2 weeks before #42044 by manual-mecanica
Hello, the corsa come monopunto and multipundo if it is mono carries a 1.5 bar pump and the multi 3.2 bar if it is a monkey and has a multi pump will consume a lot of gasol
