Problem with changes - Mitsubishi eclipse 98
12 years 2 weeks before #42078 by manual-mecanica
Changing problem - Mitsubishi Eclipse 98 Published by Manual -Mecanica
Very good morning, I have a Mitsubishi Eclipse 98, the problem is that at a certain time the changes that are down (second, fourth and reverse) stop entering), after trying several times perhaps it enters and when one enters, either of the three, they all work again smoothly until the failure appears again. It is important to clarify that the box at no time makes noise when I try to put the change, and although it turns off the engine does not enter either.
12 years 1 week before #42097 by manual-mecanica
Manual -Mecanica Response on the problem with changes - Mitsubishi Eclipse 98
mmmm spice checking the cash support, in case it leans, and also the selection is by piola right? If so, the piolas and especially the tips that go the box bring a rubber center that come out, check and warn
12 years 1 week before #42115 by manual-mecanica
Thank you very much for the answer.
I already checked everything, today I released the connectors that come from the lever to the box and tried to move the mechanism manually, but the same thing happens, those that are up ... evidently the problem is inside the box, but I do not know what it can be or how complicated and expensive to repair, perhaps it is only a piece that is rubbed or moved from place, but unfortunately there will be no other to take out the box.
12 years 1 week before #42134 by manual-mecanica
You will have to take it to take it, you want the inner leg that runs through the canal is spoiled but in disassembly there should be, first disassemble before saying anything there are some balls that also come out or fall or cool Czech and warn.
12 years 1 week before #42137 by manual-mecanica
We'll see what I am finding, I will disarm it next Monday.
It would be of great help if someone has the manual for the display of the box that brings this car.
Greetings and as soon as I have a novelty I share it in the forum.
