fuel consumption
12 years 2 weeks before #42079 by manual-mecanica
fuel consumption published by manual-mecanica
I have a Dodge Ram 50 Model 1988 with a 3K carburetor the problem is that it consumes a lot that had some advice with this problem and I hope some response soon
12 years 1 week before #42098 by manual-mecanica
Manual-Mecanica Response on the topic fuel consumption
They changed the carburetor but check that they were carburad, trying the passage of the gum and try how you are doing, beware of the float and the flute, also remember to check the fuel pump if you put it electric and it was mechanical, you will check the precion.
12 years 1 week before #42183 by manual-mecanica
Hello and thank you very much for the answer but the bomb I had was electric that goes out of the tank and changed to a new but not for an original will have to do with the type of pump that sends more fuel than the old woman. To the carburetor, an adaptation of fuel return was made because the carburetor did not have and how to try if it is the fuel pump that is making more fuel
12 years 1 week before #42194 by manual-mecanica
I measure the fuel pressure, I would not overcome 1 bar plus that was the range they had is that there are some that are exterior but are of greater pound.
