Good morning, it is the first time I write in this forum, I need your valuous help, if someone can guide me it is this problem, I have a 92 1.8 liter 4-cylinder model, which does not start because the current does not reach the hall sensor, which has an harness of 3 terminals which are land-pole-corner, the current cable goes directly to the computer in the pin number 8 according to the diagram of the number 8 Digifan II, my question is whether the computer is the one that must send the voltage to the sensor or vice versa? I clarify that when you put direct voltage of the battery the car starts without problems, thank you very much for the information you can provide, greetings
