Neon 98 does not start
11 years 11 months before #42336 by manual-mecanica
Neon 98 does not start published by Manual-Mecanica
The problem I have is as follows:
A Neon 98 starts with the disconnected camshaft sensor, fails, connecting said sensor and completely turns off the car, I try to tear it out again and just go and there are no pulses in the coil or in the injectors.
I hope you can guide me
11 years 11 months before #42338 by manual-mecanica
Manual-mecanica response on the neon 98 topic does not start
That is typical of short sensor by dough. If you have a scanner, do it to know exactly if it is short of the sensor or wiring
11 years 11 months before #42339 by manual-mecanica
Well, I think about it and as a solution cut the lines of the crankshaft sensors (CKP) and the camshaft (CMP) and put others as a test and change both sensors for some that I had in good condition and there was no change
11 years 11 months before #42340 by manual-mecanica
Because I think about it and as a solution cut the lines of the crankshaft sensors (CKP) and the camshaft (CMP) and put others as a test and change both sensors for some that I had in good condition and there was no change.
11 years 11 months before #42345 by manual-mecanica
