The electrventilator does not stop
11 years 11 months before #42362 by manual-mecanica
Hello, I have a partner '9 when the vehicle starts, turn on the electrventilator and it is working. What is the fault? It runs the risk of burning?
Thanks
Daniel.-
11 years 11 months before #42379 by manual-mecanica
Manual-Mecanica response on the subject The electrventillator does not
It is likely that the relay, controllao, burning, is not stuck but wears the divine button. :)
11 years 11 months before #42382 by manual-mecanica
Surely you are giving problems the thermocontact (try to decone it and if you stop you already know that you should change it).
All the best.
11 years 11 months before #42388 by manual-mecanica
Change the relay must be hitting, there to get the mask for acseder to it, the fans do not burn because they are constantly in operation that is a myth, there is more obio wear but do not burn.
11 years 11 months before #42390 by manual-mecanica
Thanks for the help, the circuit was ok. I cost me the relay, who are in front of the front. It should be a code error in the ECU, which did not receive the electros stop signal. To solve it, draw the relay and let the engine take temperature and thus obtain the signal then place, closing the circuit. And finally check that you will take the steps on and off according to the temperature.
Greetings Daniel-
