It does not go from 80
11 years 11 months before #42422 by manual-mecanica
It does not go from 80 posted by manual-mecanica
Hello, good morning,
I have a problem with an Opel Vectra del 98 that does not go from 80 I have walked the EGR valve and the air flow but remains the same with the light on and it does not
have if you do a hand a hand: Dry: a hand
11 years 11 months before #42434 by manual-mecanica
Manual-Mecanica response on the subject does not go from 80
You will have the vehicle in failure, the UCE limits the car to make a workshop.
put a scanner and see what failure gives you.
11 years 11 months before #42444 by manual-mecanica
It is true the best thing you can do is run a Scaner to see the fault.
