ORDER OF BIJIAS RENAULT LAGUNA MOTORN7Q
11 years 11 months before #42568 by manual-mecanica
ORDER OF BIJIAS RENAULT LAGUNA MOTORN7Q Published by Manual-Mecanica
My problem was that I change the ignition coil and the cables but the car makes me some against explosions now I think that the order of the cables is wrong and I wanted to know if someone can help me with the order of the cables
11 years 11 months before #42579 by manual-mecanica
MANUAL-MECHANIC APPLICATION ON THE ORDER OF CLABLE OF BIJIAS RENAULT LAGUNA MOTORN7Q
I tell you the type of engine, it will not use the sullo, it would be to know year of the car or type of ignition of the Co?
The ignition order is 1-3-4-2, if there are 2 coils with 4 outputs you put cylidro 1 and 4 in the top coil <-la that is closer to the abitacle).
and on 3 and 2 in the coil that is closer to the radiator.
I do not want to mess you up: cylinder 1 is looking at the engine on the left and the 4 that is near the gearbox.
If it is from the time in a schedule you put 1-3-4-2 there are only 4 options, you are trying to be heard hehe.
You already tell us if you have doubts or if you solve it.
11 years 10 months before #42667 by manual-mecanica
You can resort to old school, take out the spark plugs and tour the engine by hand or with a touch of start and look at which cylinder is blowing there is only one
