Estimated
for a while now, the direction of my terrano truck, (frontier elsewhere) comes with a problem, which being parked or turning in a corner, behaves like a mechanical direction. Remove the pump, I checked all its internal components and look in good condition, the pump is a VK-513 type. I did everything indicated in the different videos and informative that I could read, however, I can not repair the failure. I use the right oil, and the belt is good.
I only doubt the flow valve .... maybe it is being stuck, but I have no data to check the pressure or other way of verifying it. Can someone give me information or other valve inspection, at the moment I have it unarmed and can revive it? Of course, thank you very much for your help
