hello. Having if someone helps me, it turns out that I have a 1.9 d pole AEF engine and had the bad contact wash and YL transponder spliced and I brought to scrapping keys bombin and transponder and mount everything separately changed distribution strap and now does not want to start. He tested to peel the engine two thousand times and nothing impossible to start. I don't know how to make him part of cojust and put a mecherito and burn. have if you can help me.
Yes. The easiest is that you will throw gas on him and set him fire. But out of jokes, I in your place, if you already have more than the distribution, check that the transponder and the car key have the same signal. In the scrapping, of a car that has the same motor code as yours.
