Hello friends of the forum. The following is, a few months ago the MAF sensor of my car was a Nissan Sentra Tsuru 2006 with GA16DNE engine, which is 3 pins. This sensor has a code that says AFH45M-46, as I live in Nicaragua, here they are not sold new, looking for any used and nothing, because it turns out that I find an equal but with the AFH55M-10 code, install it and then work the car. After this, the TPS was broken, I changed it to a new one with the same code, but now when the TPS calibrates, it no longer works with 0.58 volts, but with 0.08, if I try to upload it to 0.20 or more the car is kept accelerated to 2000 or 2500 rpm.
My questions are the following friends and maybe they can help me:
1- Will my car more consume with that MAF or will it be better to change it for the original code it brought?
2- Will I have to reschedule the ECU for the TPS?
3- Even if the car runs well and everything will be convenient to leave it with those parameters?
4- Will the IAC valve be giving me any problem and that is why the car regulates with the TPS in that voltage?
Thanks for your contributions.
