Case in a Mazda 2
11 years 10 months before #42789 by manual-mecanica
Case in a Mazda 2 published by Manual-Mecanica
Cordial greeting.
I have a mazza 2 with bells problems, it is an automatic 1.5 and when it takes good temperature, the rattle increases, already performs tests with fuel and with additional spark plug change does not present any fault code.
If you can help me mail
thank you so much.
11 years 10 months before #42790 by manual-mecanica
Manual-Mecanica Response on the Caser Theme in a Mazda 2
Look, the most normal is that they feel rattle with low temperature when it comes to wear inside the engine since in high temperatures the material expands reducing the slack so I think that most likely it is that you have a problem with the ignition, put it ready and see how it works
