The first thing is that you look for one in scrapping and put it, do not listen to jilipolle that it will be better without it .. the calculation is the one that is and there is no more, unless you want to change injectors, switchboard and everything to get out more expensive than 16v, I have a caliber that came like this, and it would not use anything without catalyst, also the pole empty it because it was broken because it was broken because it was broken because Ponsate and leave, pay me attention if you want, Citroen engineers are not idiots, think about it ..
