Nissan problem
11 years 10 months before #42862 by manual-mecanica
Nissan problem posted by Manual-Mecanica
Hello I hope you are well all the forum!
My problem is that I have a Nissan X-Trail 2005 engine YD22 and that is that the car repairs it and all full but turns it off and disconnected the button of the butt of the cylinder head and connect it again and does not want to turn on any more !! I would thank you for helping me !!!!
11 years 10 months before #42866 by manual-mecanica
Manual-Mecanica Answer on the Nissan Problem
Hello at first glance for what you tell us, two things occur to me:
did you disconnect it? Or did you disassemble it? If it is the first thing it may be that the switchboard is recorded the error, which you can try to erase it with a diagnostic machine, if you disassembled it and moved the car and the position of the sensor with respect to the camshaft change, surely you have "left point" to put it to point you will need the workshop manual.
In the autodata (Mechanage program) everything comes out, electrical schemes checks, distribution, etc ..
greetings
11 years 10 months before #42915 by manual-mecanica
Hello, I hope that you circulate
the sensor that you were discharged is the CNP and it means position of the camshaft is synchronized but according to what you tell me is that I do not start more which is strange that the only sensor that when this fails this is the ckp sensor of the crankshaft, I recommend three things.
1) Limpa the contacts of the sensors of the cylinder head such as that of the crankshaft (with the battery disconnected from the negative during an ohra aprosimally).
2) Once this connects the battery and gives contest and waiting for a minute, then starting to fail but wait until the electro starts and would be ready.
