Peugeot 206 1.6 piston brands
11 years 10 months before #42886 by manual-mecanica
Peugeot 206 1.6 piston brands published by Manual-Mecanica
The piston arrow where you must sign up for the gearbox, or the time strap.
It is a Peugeot 206 1.6 Model 2007.
Because the first bench is on the side of the gearbox.
What is the engine front?
11 years 10 months before #42908 by manual-mecanica
Manual-Mecanica Response on the topic Piston Pistonot 206 1.6 1.6 1.6
Hello, if you are not going to make a change of pistons I suggest that you put them the way you took it out, they should be pointing to the side of the synchronism belt, I hope it will be useful for the info, the info is useful,
