Repeali very high in 7afe engine
11 years 10 months before #42900 by manual-mecanica
Repeali very high in 7afe engine published by Manual-Mecanica
Hello, I have a 97 corolla with 7AFE engine and recently the slide is accelerated a lot, leaving about 1300 rpm, change the sensor that closes the air valve and did not improve: Dry: I would like tips or instructions to be able to solve it ... because the fuel consumption went too high: UNSURE: : Angry:
11 years 10 months before #42904 by manual-mecanica
Manual-Mecanica response on the very high slowdown in 7afe engine
Hello, it measures resistance temperature water in butt, disassemble and heat it and measure again if its resistance has varied, if not, defective and increase the injection flow as if the engine was cold, it increases the consumption and the hot slowdown rises as if it wearing a thrown starter. If not the problem is usually of air mass measurement, it is decit caudalimetro, greetings
