VW Bora goes out
11 years 11 months before #42969 by manual-mecanica
VW Bora is turned off by Manual-Mecanica
Greetings to all:
I tell you that I have a small problem with my Bora 2.0 cc; It happens that when 1/4 tank has left, or a little less fuel, the car is usually stopped (as if it had no gasoline) .This will start, it starts without problems, as if nothing happened, and it can fail again or not .. the tank is clean, there are no traces of water, it has the corresponding breakwater and the fuel pump is new original.
The level marker works perfect, and if I have more than 1/2 tank, there is no problem.
What can be happening?
Of course, thank you very much !!!
11 years 11 months before #42977 by manual-mecanica
Manual-Mecanica response VW Bora theme
I had three problems equal to yours, the first happened with a Chevrolet S10 and the problem was that the fuel tank was detained and the lottery marked bad mystery and marked a room when it really was dry
