EUROVAN DIESEL 1.9 TDI does not start
11 years 10 months before #42981 by manual-mecanica
EUROVAN DIESEL 1.9 TDI does not start published by Manual-Mecanica
Urgent help, I have a Eurovan TDI Diesel 2008, which does not start, I don't know what you have. The detail is that with starter if it starts but it does not accelerate, but if I stop starting it, what can I do thanks
11 years 10 months before #42986 by manual-mecanica
Manual-Mecanica response on the issue of Eurovan Diesel 1.9 TDI does not start
You can start by releasing the tube that Gasail to an injector and see if it throws diesel.
The diesel filter if it is very old, it would be good for you to change it.
For the year I think it is eateid that engine once you see you get Gasoil looks out of getting an injector and you start to see if pulverizes
11 years 10 months before #42990 by manual-mecanica
Before he stopped turning on, what works did they do?
did it go out and stop starting?
Have you assured you that the fuel system is well purged?
Specifically the filter, fill it with diesel to make sure it has no air.
What scanner do you use, do you have guided functions?
What DTCS presents?
It also verifies that the fuel pump is working.
Do the tests and notify me please
11 years 10 months before #42997 by manual-mecanica
How good day.
Look, this truck was amended and ring because as I had no compression on the pistons, the fault is that the walkant walking, he lost the power, it had to be turned off and walking so that Hagarra Power, the climbs could not climb them to more than 20km/h, so it is ring, once the engine was armed, the engine was no longer Cams was burned, it is already changing, the fuel filter is also changed, the tamdem pump is already checked, if fuel reaches the pump, but with everything and that does not start, it only starts with starter, which when it stops it is done, will know how the cables of the camshaft sensor are connected? thank you
11 years 10 months before #42999 by manual-mecanica
As the classmates say the problem is in the injectors or the system that makes them function as the Czech Driver Driver sensor Driver de CPU RESTORES
