Opel Corsa C 1.7 DTI alternator
11 years 9 months before #43052 by manual-mecanica
Manual-Mecanica Answer on the alternator Opel Corsa C 1.7 DTI
Ok, if so, does the depressor have to do with the car oil? I want to empty it to change it for new oil. If I empty it before and leave the plot removed from the carter, it would not fall oil?
And finally, is the depressor independent of the alternator? Works through the axis it carries? If you look at the alternator, it is pringeled oil. Any board or something of the depressor is broken?
Well nothing, greetings
11 years 9 months before #43075 by manual-mecanica
Schec the alternator can fall oil from many sides but it may be that the joint is broken, the motor oil is the same of the detension, if you take out the plug the carter oil falls but in the line of the depressor it will still look because everything never comes out when you take out the plug
11 years 9 months before #43099 by manual-mecanica
Well, it seems that everything correctly disconnected and ready to extract it, but now that ??
Where can I get it ?? Do you have to disassemble something else?
since where the alternator is located I can not take it out.
Any idea ??
[IMG
Uploaded with Imageshack.us
11 years 9 months before #43100 by manual-mecanica
Any idea ??
[IMG = http: //img89.imageShack.us/img89/2111/tof5.jpg] [/img]
Uploaded with imageshack.usus
11 years 9 months before #43101 by manual-mecanica
