Hello, I can't take off the homocinetic of the dough
11 years 9 months before #43035 by manual-mecanica
Hello, I can't get a homocinetic from the dough, someone is hit that threw an idea
11 years 9 months before #43040 by manual-mecanica
Manual-Mecanica Answer on the subject Hello, I can't take off the homocinetic of the dough
When it happened to me, the demant and sack in the press.
11 years 9 months before #43042 by manual-mecanica
Thanks Pedro, but I did it and I don't go out with the 2 -ton press, I'm going to see if I get the 15, greetings
11 years 9 months before #43051 by manual-mecanica
You have to hit it until it comes out, it can also be heated, in the press when it does not come out, you give it pressure and you hit it at the top to loosen, this is also done with the bearings.
11 years 9 months before #43143 by manual-mecanica
If you see that there is oxide and the work is due to that, let the mechanism in water submerged for a whole night. Water with prolonged time is the best to loosen what is oxidized.
Logically, before assembling again it is advisable to clean very well and lubricate.
