Lamda probe
11 years 9 months before #43156 by manual-mecanica
LAMDA probe published by Manual-Mecanica
Friends I tell you, I need support with the installation of a 4 -way lamba probe in a f0 byd which changes but I still throw error the question is the F0 will have the changed cables of the probe as the signal outside the earth is a favor help
11 years 9 months before #43158 by manual-mecanica
Manual-Mecanica Answer on the topic Lamda
Let's see, the Landa probe is a sensor. If it gives you mistakes what can be ???
You have to ask yourself, that it is failing so that the Landa value is altered.
If the code gives you a Landa failure it does not mean that the Landa is broken, but the (CO) or (oxygen) are uneven.
Look at the EGR, which does not find cracks where the air can enter the exhaust or admission collector, that the injectors are spraying and does not drop into the cylinder, which is burning oil by a joint that gives way to the engine.
way to know better you put an exhaust gase meter if the meter fails, because you know is not the Landa.
And if the meter gives you well then check the cables or look if it carries 2 las.
11 years 9 months before #43160 by manual-mecanica
If it has 2 lamdas anterior media the probe with a Scaner which did not mark the indicated values ​​was stuck in 1 volt and does not recover it with a tester which threw me the same thing I changed it but it remains the same way they told me that the surgeo of the chinos cars comes the cables to the remote the row lamda that put it is a bosh standar
11 years 9 months before #43209 by manual-mecanica
There are four cables there are two of the same color that are from the internal heater, the earth is black and the signal the Plomo.
