Kia Sportage 1998 Autodiagnosis ??
11 years 9 months before #43180 by manual-mecanica
Kia Sportage 1998 Autodiagnosis ?? Posted by manual-mecanica
Does anyone know if it is possible to perform any self -diagnosis to obtain failure code, bridging the 20 -pin data connector? as is done in some other models.
Greetings.
11 years 9 months before #43210 by manual-mecanica
Manual-Mecanica response on the Kia Sportage 1998 self-diagnostic theme ??
What year is the Sportage?
11 years 9 months before #43232 by manual-mecanica
Year 1998 2.0 DOHC. What I did was to bridge in the diagnosis plug as is done in a Kia Sephia and thus tell the pulses of the check Engine and take out the code, but as confused. It happens that 2 wet spark plugs leave. Compression 160-170 in the 4 cylinders, OK coils, exchange and the same, OK cables. Injection resistance OK, pulses ok. Comb 40psi pressure OK regulator.
greetings
11 years 9 months before #43234 by manual-mecanica
Hahahahahaha I tell you to the touch the kia sportage has two green injectors and two oranges, it has happened to me in several of those that the orange injeaders are prove The lid is heated more the cables and the spark starts, I tell you for something Walter You know that I do not lie to you, I forget to answer the theme of the mitsubishi lancer did you solve it now?
11 years 9 months before #43235 by manual-mecanica
Ha how data when the injectors were wrong, I didn't have check on or anything
