greetings to all in the forum .. I have a nissan xtrail that yesterday the engine assembled with everything the problem is that the e Onndrla started well but after a while the light of oil witness began to turn on with the low revolutions and when accelerating it goes out I have the oil pump is new and the engine turns on a when I ignore but it is afraid to think that the chain could have been I know if it can be the oil spin or that the oil pump is defective .. Help thanks.
Hello. Remove the oil sensor and connect the Example pressure meter = If your car is a Nissan Xtrail T30 2.2 DTI in idle, it has to have 0.98 bar and 2000 rpm 2.94 bar. If you have it, check the sensor or change it. You could be more specific: Mi Nissan X-Trail T30 of 2003 Example Motor YD22 2.2 114 hp. So I could help you more.
