Hello everyone, WTO electro along with greeting him, I can realize the forum, that the problems are repeated
.... From my experience in Jeep (XJS, WJS, etc.) I can tell you that these temperature problems are not exclusive to tropical areas. I live in Chile (moderate climate) and we have the same problems with these "jojitas", of course less accentuated, but they exist.
In the first one I saw, a Cherokee XJ Classic 1999 almost identical to 2000, I was able to take care as the serileimit forista, the high temperature and work of the engine, to shine everything that Esteba within my reach, reaches a situation for his
... It turned on well past 100 (103) degrees Celcius, the engine temperature reached almost 105 Celcius, until it began to decrease posteriorly by turning to 98. (Electrovantillaist function controlled by the ECU Motor), this is the normal behavior of those systems with the air conditioning OFF. Then with that question resolved, the other Jeep attack, and when reviewing the viscous coupling of the mechanical fan, I could see that it had an erratic functioning, the sound change and flow of air was not felt at any time when the viscoacker began to engage (88 degrees), perform diagnostic procedure that came out in the manual and determine its erratic function. Change the piece and everything ok.
After this investigating I could see that the ectroventillator function is only in support of the viscous system, if this fails the engine invariably nephews if the vehicle arrested. The other thing that after time observes in similar cases is that due to the high normal working temperature of this engine, the Chrysler-Jeep systems are very sensitive to the discourage viscous coupling is not OK.
In an occasion I saw a cylinder head problem, but in that case, other symptoms could be observed: refrigerant consumption, P0300 deployed by the ECU, 2 -cylinder completely decarbonized, clean spark plugs, as new compared to the other cylinders, refrigeration system refrigeration system (the hoses are not inchan), etc., etc., etc., etc., etc., etc., etc., etc., etc., etc.
I cordially invite the WTO electro forista, if you feel like telling us what the problem was already the problem and all who wish to eat opinions and/or experiences. So we can all learn a little more about these machines. Greetings atodos.
