Mercedes E320 Year 2000 6 -cylinder engine I think it is a 2.7 dci. diesel.
When the needle marks 90 or less it stops and so that it does not cool does not start.
I changed the seals of the injector ramp pressure sensor, they advised me in Mercedes that used to pass and caused a failure <-the remains the same.
The plasma fan moves. Air conditioning fans do not move. I think they should move to the plasma.
The thermocontact that is stuck to the thermostat removed the clabija and the electric fans work.
I don't know what to try, I'm going to put a thermocontact attached to butt and with an electrical fan reluctant if it heats up. <- fug.
If someone comes up with the solution or passes before you comment.
