- Thanks received: 1
06-19-2025 Hits: 549 Technology
Kikemec wrote: It begins with the simple, first check that the pond is not beaten as it has happened to me and leaves the float's leg in a given position, second takes the pump with the float and checks that the leg of the float reaches the bottom and does not remain in the middle, finally disconnect the cable of the marker the clock should fall to 0, if the clock is not done.
