Oil decanter solenoid valve
11 years 8 months before #43659 by manual-mecanica
ELECTROVALVULA Oil decanter posted by manual-mecanica
GREETINGS!
I would like to know which function fulfills the "Oil Decant Electrical Washer" of a Renault Megane 2.0cc 16V NAFTA. Vá applied in the cylinder cover, after the spark plugs. original of the piece is 8200831629.
The vehicle is aspirated, without turbo. Could it be that it works as an EGR valve?
What are the symptoms of the car when this valve fails?
Thanks to who can contribute some data!
11 years 8 months before #43737 by manual-mecanica
MANUAL-MECHANIC APPLICATION ON THE ELECTROPALVULVULA OIL DECONTROVALE
Not
what failures do you have? When starting the cold engine does a strange noise? Metallic? If so, it can also be the lipstick pulley
11 years 7 months before #43900 by manual-mecanica
Hello, that seems to me an electrovalve of a variable distribution by hydraulic, not an oil decanter, if it is what I think, what it does is open the oil passage at its own time to make the admission camshaft progress or increase more or less
11 years 7 months before #43904 by manual-mecanica
Thank you, Ismael for your answer. It has a lot of logic what you tell me. The definition of oil decantation valve, I took it from the Renault list, and that was what has confused me most.
Grateful, again.
