Change the air filter, see that the air inlet tube is not clogged, the one you say you disconnect, clean spark plugs, check motor water temperature probe, (variable resistance) and if you can, look at the gasoline regulator, and if all this does not, change caudalimetro, if either, before paying 6000, sell it as is ... come out winning. luck
