Ford Escort TD 1.8 of 98 '
11 years 7 months before #43871 by manual-mecanica
Ford Escort TD 1.8 of 98 ' Published by Manual-Mecanica
Greetings, I have a Ford Escort to which I had to change the engine. The problem is that by changing the engine I give contact and everything goes perfectly but when you start it, it does nothing. Would anyone say what to do?
11 years 7 months before #43892 by manual-mecanica
Manual-Mecanica response on the topic Ford Escort TD 1.8 of 98 '
If you do nothing at all that is the engine does not rotate or anything, the sheet is not exiting the starter engine, you will have to check if the sheet of sheet mets, if it does but still does not turn then it is a problem of the rherake itself
