Peugeot 307
11 years 7 months before #43972 by manual-mecanica
Peugeot 307 published by Manual-Mecanica
Hello, I am a mechanic and I have a problem with a Peugeot 307 2000 HDI. It has an exaggerated consumption of antifreeze without any evident leak and does not accumulate pressure or rise the temperature of 90º. Where does the water go? We will have to remove the cylinder head and make it analyze?
11 years 7 months before #43975 by manual-mecanica
Manual-Mecanica Answer Peugeot 307 topic
Look if you throw a lot of steam through the exhaust pipe, if so, it is surely damaged butt joint, you also check from the companion's side if you are not wet or wet the floor because they usually lose by the heating radiator, tell us how you v, greetings.
11 years 7 months before #44020 by manual-mecanica
You have the cylinder lid cracked and it is usually started by the escape when you walk
