Ford party does not start.
11 years 7 months before #43994 by manual-mecanica
Ford party does not start. Posted by manual-mecanica
Hi, I have Ford Fiesta, Mod 2005, it does not start, it gets in touch nothing more and scan it and tells me the fault of the can (communication error) that it can be. 1.6 Rocam
11 years 7 months before #43997 by manual-mecanica
Manual-mecanica response on the subject does not start Ford Fiesta.
Hi Pablochi I would like to know what scanner you have because there are many models that cannot enter. If you want to know why it does not start, it is very easy only to see if gasoline enters and look to see if the spark plugs are current, you remove one and you put it in the cable and approach it to the cylinder head or block without gathering it but close one of that two things is why it does not start by general rule.
11 years 7 months before #43998 by manual-mecanica
I had forgotten you have to start to see if spark plugs come out
11 years 7 months before #44004 by manual-mecanica
Hello thanks for responding, the car does not turn on the witness lights of the board and does not move the starter engine, it is like something that short the food apart from the board and the donkey. I have a SPC Max and I said Averia Can Bus without connection
11 years 7 months before #44007 by manual-mecanica
Did you check all the fuses?
