Luz Airbag on Daewoo Nubira 2003 KLAN
11 years 7 months before #44030 by manual-mecanica
Luz Airbag on in Daewoo Nubira 2003 KLAN published by Manual-Mecanica
Sometimes it went out after touching the connectors under seats, but in the end it was on. Does anyone have a simple and cheap solution? Thank you.
11 years 7 months before #44042 by manual-mecanica
Manual-Mecanica Response on the topic Luz Airbag on Daewoo Nubira 2003 Klan
Disconnect the connectors and notice that they adjust well, clean them with a good coal and do not make it scan to see what failure code throws, tell us how you v, greetings. :)
