Hello, good night I have a peugeot 406 and I do not stop, I get the chivato motor if it will be from the Bsi, I have tried to disassemble the pipe from an injector and it does not come out diesel cunado I give the contact
thanks in advance to see if someone can give me a hand
Look in a crankshaft collector, it usually stresses in the clutch bell, in this car, I think. Disconnect it and measure polyimeter, resistance between terminal 1 and 2 or 2 and 3, if there is a resistance of 300 to 800 OMHS, if you do not read, it is damaged. If it's okay, look electrovalvula in injector ... luck
