Nissan Micra does not start
11 years 8 months before #44049 by manual-mecanica
Nissan Micra does not start published by Manual-Mecanica
Hello good, I have a micra of 98. Each time does not start me. Is it always in the morning. The Nissan told me that I would take it just when I fail me. I have taken it but do not detect failure. When do you know what can it be?
thank you
11 years 8 months before #44050 by manual-mecanica
Manual-Mecanica response on the Nissan Micra theme does not start
Yes at times it fails you and others should not be a compression or electric problem
11 years 8 months before #44078 by manual-mecanica
Good afternoon, it is important to say if it is diesel, or gasoline, if it is diesel, they can be many things, for example. Heater .. If it is gasoline, problem in the deposit pump, in the gasoline regulator, in the PMS collector, etc ...
