Jeep Toyota Land Crousier Year 96
11 years 6 months before #44269 by manual-mecanica
Jeep Toyota Land Crousier Year 96 published by Manual-Mecanica
Hi, everyone was not here for a long time: D
I have a Jeep year 96 LAN Crousier.
Well, the following happens, the starting module, the sensors: SIDE: and the spending and check the computer, but still do not go.
They told me that the distributor was not current.
Someone can guide me, please. I am nothing without my jeep.
11 years 6 months before #44272 by manual-mecanica
Manual-Mecanica Response on the subject Jeep Toyota Land Crousier Year 96
Hello, angi80, tell me if you understand something of mechanics to be able to say something you know you will understand me
11 years 6 months before #44275 by manual-mecanica
Assuming that if, if you do not reach the distributor, if you wear a sensor in the distributor, and it does not reach current, it can be a positive positive cable, it can also be the injection reluction, or a failure in the distributor itself (slacks on the axis, cracked cover, rotor in poor condition), check the wiring that comes from the start bulb, change the high cable of the coil to the distributor to the distributor, by itself It was wrong, you'll tell us something, greetings
