I stop at the engine when lighting the high lights
11 years 6 months before #44281 by manual-mecanica
He stops when he turned on the high lights published by Manual-Mecanica
: Angry: Hello friends..The story, I have a Kia Spotage of 2000 at. Recently a week ago I fail to fail. First with the consumption of the conbustible executive, she revice the filter it seems that they never led it changed ... and I had the factory ... what I do not find are the spark plugs ... I blame the thing. Intentity of lighting both in the outer and those of the board. Walking the engine verifies if the alternator was well drawing a terminal of the battery..tio bm, but when teaching the lights stops ... Uuu I do not know more about to disarm it ... EDPET that they understand Garcias, greetings to Toos.
11 years 6 months before #44293 by manual-mecanica
Manual-Mecanica response on the subject is stopped when lighting the high lights
The problem you describe, proves the following to take a thick cable from a screw from the gearbox to El Chassis in an area that does not paint.
The good would be that you knew that current runs through the chassis of your vehicle, normally negative <-compose some strange cars that carry positive for chassis.
Knowing what example your chassis is negative, a thick cable of negative terminal battery to chassis.
11 years 6 months before #44320 by manual-mecanica
Hi Juanook, check the brooms of your alternator's regulator, because if you are already food, do not load battery as it should and ... the kia is all dead, it may also be that the alternator's diode bridge is lazy, re -pre -pre -re -pre -re -predicates it, all this is before you release the wool for another alternator, because sometimes they shit you saying that it no longer has arrangement and it is not so. You should also look how your battery is going on electrolyte ...
