Clio 1997 does not start
11 years 6 months before #44504 by manual-mecanica
Clio 1997 does not start published by Manual-Mecanica
Hello people, I tell you my problem. I have a Renault Clío RN 1997, C3L engine (1.6, 8 valves). Yesterday came calm down the route and suddenly the engine died. I tried to turn it on again, but turn and turn without starting. Apparently it is not a fuel problem, so I think it can be on. Lights, indicators and other electrical accessories work. The fuses are fine. I would very much appreciate any type of help.
Greetings
11 years 6 months before #44537 by manual-mecanica
Manual-Mecanica response on the subject CLIO 1997 does not start
The first thing that you have to check is whether there is a spark in the spark plug cables or coils and if there are no we say where to go, because if you only tell us that it does not start, so many things can be, it is necessary to check that fuel arrives, that the pump of it works, that the distribution belt is not cut, and that there is a spark with such little information is very difficult to help you.
11 years 5 months before #44616 by manual-mecanica
Greetings, this fault is very related to the strap of motor times since it must be replaced in a certain amount of travel km verifies if sparkle comes out of the spark plug cable
