Does not start - Matiz 2005
11 years 6 months before - 11 years 6 months before #44523 by manual-mecanica
It does not start-Matiz 2005 published by Manual-Mecanica
I have a 2005 kill as I said in the title, it does not start and there is no spark in the spark plugs, the switch is changed to place another key, now you do not want to start, scan it and detected problems with the crankshaft sensor and the camshaft sensor, change them, but the problem persists, the cables are fine and the current reaches the coil that I have changed but my problem is not changed. I would like to know what else I could review, because at the moment I do not know what to review the most. Thanks in advance, I would like to add a little more detail and clarify something else, a swipe change was made and a universal one was put, the car certainly worked for a short period of time but then the engine deviates, and it had 6 months without using and is kept, without battery or anything else, even recently that it was repaired in theory but I have the problem that it does not throw spark.
Last edition: 11 years 6 months before by .
11 years 6 months before #44528 by manual-mecanica
Manual-Mecanica response on the subject does not start-Matiz 2005
Hello Shother, the key of the key, that I think it can be your problem, if it is like I imagine, it has a collarin-bobbin incorporated so that I can read the starter key, you have not connected it, or it is not compatible with the anti-ranque, then it does not read and it does not come back to start, but if you have changed key, you will Transpondent chip and attach it to the new one, and you save the key encoded, look to see, those codes that the scanner has thrown is when the engine is stopped surely, ignore them then ... greetings !!!
