- Thanks received: 1
06-19-2025 Hits: 479 Technology
... ah !!! You may ask the manual to change seals as appropriate to do it, taking advantage of the disarmament you should change tensioners, auxiliary bearings and water pump if applicable.Mov1973 wrote: Hello. I am very attention what you ask. In the time that I have been working on this I have ever had to take out the piñón from the camshaft neither with a key nor conical from any engine for a belt change ... I do not see necessary to do it, nor such special tools to change a time band ... only locates the corresponding marks in the same camshaft, crankshaft or injecting pump if applicable ... remember that every engine brings its manufacturing marks either in the same pine of change boxes. luck
