Hello Etiodelsofa ", the pump will take it in the lower part, inside the distribution strap cover, if you get underneath, you will see that it drips from inside the lid, if so, remove the tapas and you will see is escaping for a hole that has just below the pinion, there is no more. You can also look where the sleeves hug I advise you to walk with the parther, nor that you throw more than a liter with the hot engine, if you have to change pump, take advantage of the belt if you already have km.
