Peugeot 206 tuning
11 years 5 months before #44693 by manual-mecanica
PEUGEOT 206 PUBLISHED BY MANUAL-MECANICA
Please I just set up a Peugeot 206 and I can't start it, they can tell me how to set up the enlargements of the distribution
11 years 5 months before #44695 by manual-mecanica
Manual-Mecanica response on the topic tuning Peugeot 206
Hello, you should say that the engine carries, well, assuming that it is gasoline (Mot. You) you must put a screw on the camshaft pulley (wears a hole) and nest it in another hole that carries in the butt, to peel the crankshaft, in the right side of the block, in the union with the change, it carries a hole in which you should put a 6 mm pin of 6 mm diameter to a depth of 27 mm when It is inside the engine steering wheel. For camshaft it is 10 mm x 50 mm diameter. If it is diesel you must peel the pulley with two 8x50 screws in the holes that this brings and threading them to the block. To locate you well, I advise you to download the corresponding manual here on this page. Greetings!!
11 years 5 months before #44696 by manual-mecanica
I thank you for that already, the problem is that it does not make me an explosion, the engine is like that the gasoline does not suck, it remains in the admission
11 years 5 months before #44697 by manual-mecanica
I do not understand you well, if the belt is well placed, then the problem is another, if you can tell you to mean "I have left in admission .." We can help you. greetings!!
11 years 5 months before #44698 by manual-mecanica
I think that what may have happened to you, is, if the taques are hydraulic, that the valves have been torn on ... and then there is no compression ... and do not start .. correct me that if the taques do not empty, they are full of oil and then this pod comes. If this is, as everything is mounted, to turn it to hand, until you empty ... quotes the apron cover to see if this is happening to you .. greetings!
