Peugeot 806 does not start
11 years 5 months before #44828 by manual-mecanica
Peugeot 806 does not start published by Manual-Mecanica
Hello everyone!!! I have a Peugeot 806 of 95-96, and from good to first it does not start, from battery it is well I have verified it but when throwing to start it does nothing or the attempt to turn, they have told me that it is of the implementation that could have been taken, but I would like
to make sure before disassembling anything.
Thanks and greetings .....
11 years 5 months before #44831 by manual-mecanica
Manual-Mecanica response Peugeot 806 topic
Hi Nando, if you do nothing, the problem is the same in the key of the key (I mean the switch that is connected in the bombin), it may also be that if it has many km, the starter engine has any problem: or the solenoid is damaged (cut coil, axis grabbed by dirt ..) or the engine brushes are spent. Test putting a direct cable of the positive battery at the starter engine. Greetings!!
11 years 5 months before #44958 by manual-mecanica
It is true or is the contact sheet or the starter engine, or some cable that you are released
