Nissan Terrano 1991 Automatic Box Problems
11 years 6 months before #45220 by manual-mecanica
Manual-Mecanica Response on the Nissan Terrano 1991 Automatic Box Problems
Hello everyone, the range sensor seems to me that it is going under the lever, I agree with you that most likely is an electric drama (range sensor) as it told you when you are in N, reports a caputer that you are in neutral, that is, it leaves all free clutches without pressure, when the contact sensor contacts begin to fail, at first, at first, usually by accumulated dirt, they delay to recognize the accumulated dirt. Position of the lever, I do not know if you understand me, then when the sensor stops working properly the controller computer of the box, stops receiving the info of the position of the lever, if the connector that you disconnected, is that of the appointed sensor, the box enters emergency mode are only in 3rd, so you can repair it. Look for a long time since I see a terrain of those, it seems to me that the Sendor is going under the gear lever, in any case, if you do not detect the fault, cooking to take it where a serious person and that he knows these boxes, see that by here it is full of scoundrel Balance, but if it is not serious they will disassemble the box, they will change everything inside or they will not do anything and then the eggs are done and if I have seen you I do not remember, of course not everyone is like that, but there are many people little would be that tells you that they understand this and then ....
11 years 6 months before #45225 by manual-mecanica
Look that is exactly what happened when I disconnected it could just walk until third ... and indeed before it I failed to take more and more when I go from N to D ... I greatly thank you for the help you have given me and see if you could send me your phone number in intern to locate this sensor that still does not find it ... in advance thank you very much ...
11 years 6 months before #45226 by manual-mecanica
Hello everyone, Chavoco, now I am a little busy, I promise to check my info at night, and then with the clear panorama we talk, do you think? I give you my cell, but I would like to review manuals so that my help is fast and effective. greetings. :)
11 years 6 months before #45230 by manual-mecanica
Hello everyone, Chavoco, I empt my cell by private message, at night I check the info and communicate.
