My Inca Seat does not start in cold
11 years 5 months before #45474 by manual-mecanica
Mi Seat Inca does not start in cold published by Manual-Mecanica
Hello everyone, this is my first time so I hope to explain myself well and that I understand.
start in cold
11 years 5 months before #45476 by manual-mecanica
Manual-Mecanica Answer on the subject My Seat Inca does not start in cold
Hi Manuru, I suppose that in this model does not carry cold boot cable, so look at the 50A fuse first. lest there be some short circuit in heating wiring, then check the temperature probe and measures resistance between poles 1 and 3 must give 20º about 980 to 1180 ohms, if it is outside these values, it may not be signal to act for the heating module, (if the probe is fine, also check that it reaches current to this module)
* If you want more information, I recommend you download the manual Ibiza-Cordoba/97 "In the Manual Section (there comes your engine) Greetings !!
