CODE 8 ACCORD 5GEN
11 years 4 months before #45639 by manual-mecanica
CODE 8 ACCORD 5GEN PUBLISHED BY MANUAL-MANICA
For those lucky who have the Honda Accord of fifth generation (from 1994 to 1996), code 8 usually appears when the ECU-ECM scan.-
of
the head sensor Put ourselves completely disassembled, it is
advisable elastic characteristics and gets crowded, until cracking or cutting.-
Remedy decoupling the distributor of its place, marking the oning of the ignition. Remove it and change that O'Ring for new and identical characteristics.
After cleaning the interior of the distributor, assemble again.
Remember to scan again and if everything is ok, try to erase the error.-
If this error appears again, it will tell us that the crankshaft position sensor, effectively will give us a future problem.-
Unfortunately, the three sensors should be changed together, since they are already coming like this.-
Luck!
