- Thanks received: 1
06-19-2025 Hits: 710 Technology
Abbaco wrote: The crankshaft position sensor is probably giving you problem, it is very common in this model. Another thing is that you have synchronized the belt with the pinions but they did not synchronize the mark of the pump axis, since for that a spice tool is needed, send your address of E mail to send you the photos since I try to add them here but I could not
Kikemec wrote: I start throwing you, but I start very short and if you get your foot from the accelerator, go out? Made smoke but not so much? Does not keep alone and when squeezing the clutch stops? When does it start has no strength? If you have those symptoms, the dog pump pump dogs, I spend a berlingo, that's why I tell you and I porfiad that it was not the distribution until I stay more to disassemble everything again and I realized that the bomb had two positions
