I have a problem with a Ford Focus, I was in normal and suddenly turned off, when checking it unique outside it was a sensor that goes through the injectors that was disconnected, but even now connected it does not turn on, there is no current in the spark plug cables and in the gasoluine pump.
I would very much appreciate your opinions and advice
Hi Mr.a, check it the crankshaft collector (measures its resistance between 1 and 2) the camshaft collector resistance. Check the injection system (we don't know the engine model you carry). Check the anti -theft function (coded key etc.. This already with Ford program) if pilot turns on. We need more data to know what injection your car and the engine bring, to help you. Greetings!!
Generally when injector and pump signal fails it is for something electric that can be from a fuse, contact sheet, relay, etc. and as Ismael Czech says that the immobilizer is not active
