The fuel pump signal of the deposit comes from a relay of the fuse box of the engine compartment, I put an approximate drawing of which it is, anyway, kikemec and make a diagnosis of damage if you can before doing anything.
Coincidentually I had a similar problem with a van like that recently and the problem was the tube of the high pump entrance that was broken and air entered the fuel, the symptoms were lack of power at full load, breeding light and motor stop, after a while I started again and so, I do not remember the exact fault code but it was a lack of pressure in the rail, so better look at the DTC`s that you have memorized, since you can guide you Much about looking at.
Eye, I have made the drawing by heart since now I do not have the scheme, if it is not that of the arrow is the one below, I hope it helps you.
